CARDINAL SCALE-DETECTO IB800 DETECTO DIGITAL STRETCHER SCALE 750 INDICATOR WITH LCD DISPLAY 800.0 LB X 0.2 LB 272.1 KG X 0.1 KG BATTERY OPERATED
Designed for fast accurate and heavy-capacity patient weighing the IB800 scale features a flame retardant antibacterial self-deodorizing stretcher which is placed under the patient and hydraulically liftedches from the bed. The touch of a button gives a digital readout of the patients weight. The tare function lets you subtract the weight of bedding. One nurse can quickly gather data from an entire floor without wasted motion or patient discomfort! Safety featuresclude locking casters and lockable base widening stance for stability. The IBFL500 and IB800 are not for patient transport.
Capacity: 800 lb x 0.2 lb / 350 kg x .1 kg.
Base: Adjustable.
Door Width Clearance: Fits through 32 / 81 cm doorways.
Stretcher: 6 (1.8m) long Sure-Chek 44XL fabric.
Under Bed Clearance: 4.8 (12 cm) high.
Overload Stops: Prevents damage to weighing sensors.
Power: 6 AA size alkaline batteries or optional AC adapter.
Price: 7831.67
