CARDINAL SCALE-DETECTO IBFL500 DETECTO DIGITAL STRETCHER SCALE FIXED LEG 750 INDICATOR WITH LCD DISPLAY 500.0 LB X 0.2 LB 272.1 KG X 0.1 KG BATTERY OPERATED
Detectos digital-bed scales feature Sure-Check flame-retardant anti-bacterial 6 ft / 1.8 m long stretchers which are placed underneath the patient and hydraulically liftedches from the bed for weighing. They feature locking casters adjustable weighing arm and sturdy steel construction. The ZERO key allows staff to easily subtract the weight of bedding. One nurse can quickly gather data from an entire floor without wasted motion or patient discomfort! The IBFL500 and IB800 are not for patient transport.
Capacity: 500 lb x 0.1 lb / 225 kg x .1 kg.
Base: Fixed.
Door Width Clearance: Fits through 36 / 91 cm doorways.
Stretcher: 6 (1.8m) long Sure-Chek 44XL fabric.
Under Bed Clearance: 4.8 (12 cm) high.
Overload Stops: Prevents damage to weighing sensors.
Power: 6 AA size alkaline batteries or optional AC adapter.
Price: 5405.37
